j-d's avatar
j-d
Explorer II
Apr 27, 2013
Float Issue new Carb on ONAN Marquis 5500
Neighbor replaced his carb because the original was gummed up when he bought the coach used. Installed a new ONAN carb and soaked the original in SeaFoam. Today, genset wouldn't run. Swapped old carb back on and it ran well.
Took new carb apart and the float wouldn't drop! It's a plastic float and apparently swelled a little where the pin goes through. Not the hole, but the two edges that drop into the carb body. Filed away some plastic and float drops again. Odd. The thing's so new it barely smells of gas.
Just another gremlin, thought you'd like to know.
  • Same thing happened to me! Just got a new carb put in a year ago by Cummins while we were wintering in Florida. They replaced it with the new updated (California specs) 146-0663. :) On our first summer non-electrical family get together, the gen ran about 20 seconds and then died. The fuel pump seemed like the probable culprit, so when I got home, I ran the pump; and it was not only working, but running back out of the air intake!!
    So . . I figured that since all of the adjustments on the 146-0663 are sealed, I figured that would also apply to the main jet/fuel; and especially after my first half-hearted attempt to pop the plastic thingy off of the bowl.
    So . . . I figured I was stuck with buying another carb, and called Cummins Canada to set up a service visit. Wow! Totally different than Cummins in Forida!! And in a very bad way. They don't have time nor inclination to to service rinky dink RV stuff; nor do they even carry the parts! Not only that, but they couldn't provide useful information as to where I could get it repaired. So I called Hitch House in Barrie, Ontario; and told them I wanted to arrange a service appointment to get my carburetor replaced. At the outset, they tell me:
    1. 2 hours labour charge to diagnose the problem!! There was nothing to diagnose! . . . I just want my carburetor replaced!!:R
    2. They don't carry the standard Onan carb which fits every Onan for the past 15 years, in stock. :R
    3. So . . . now to order the carb. The parts department checks the cost of a new carb, and exclaims: Wow! That can't be right!! :? $474!! Let me call Cummins (Ontario) and verify that! Fifteen minutes later, I get call back. Nope! A new carb is NOT $474!! It is actually $596.00 !!!! Not only that, but there is only one 146-0663 carb available in all of Canada!!:R
    Well . . . goody for Cummins Canada. Just hope that if your Onan fails, it doesn't happen in Canada!
    Anyway, this whole effort significantly inspired me to take another look at my 146-0663 carb. And I learned:
    1. With nothing to lose, In got a big honkin' screw driver, and the altitude thingy popped off, allowing bowl removal just like to good ole' carbs.
    2. Sure enough, just as OP j-d said, the plastic float had swollen (or whatever) causing the float to bind.
    3. Enough for one day. When I start doing stooopid things, it's time to shut down for the day. Tommorow, I am going to shave down the sides of the plastic float fulcrum, with reasonable expectation that this $900 problem will no longer be a problem. ;)
    UPDATE: I successfully finished the operation today, and everything is running great again. I sanded off about .07" off of each side of the float fulcrum, and that's all that was needed for free operation of the float. I also scraped a bit off of the arms just above the fulcrum to make sure that wouldn't get snagged as well.
  • j-d's avatar
    j-d
    Explorer II
    No, the new carb was placed in service, then removed and dismantled when genny wouldn't start for coach's next outing. Okd was soaked in SeaFoam, and I believe with the float out.
Having RV issues? Connect with others who have been in your shoes.24,343 PostsLatest Activity: Dec 11, 2025
