j-d
May 12, 2017Explorer II
What is the Ignition Coil like? The older 460's had the oil-filled-can, and they tended to break down with extreme heat. I don't know if the newer epoxy coils were as trouble-prone.
How did you "remove the CAT?" It seems unlikely to me, that the exhaust would plug up hot but not cold, though. But if you put a bypass pipe (for testing only of course) in place of the CAT, something else could still be plugged.
Having RV issues? Connect with others who have been in your shoes.24,396 PostsLatest Activity: Jun 23, 2026
