MEXICOWANDERER
May 15, 2017Explorer
Back in the late 80's when folks begged me to cure repeated failures in the distributor mounted version of this nightmare I found Ford in their infinite ignorance of things electrical decided to use silicone GREASE as an interface between the aluminum module base and distributor. I replaced with TRANSPO manufactured modules and white zinc oxide thermal compound and that was the end of the issue. I was around 5 additional years to witness no further failures. Ford also used wires with crummy insulation INSIDE the distributor. have doubts? Look at the wiring insulation of the 2/0 diesel battery cables.
Having RV issues? Connect with others who have been in your shoes.24,396 PostsLatest Activity: Jun 23, 2026
