dougrainer
Jul 31, 2023Nomad
2000flair wrote:dougrainer wrote:
The 2 bottom ones are ground frame connections. The other may be the same, but does it have 12 volts positive on it? Doug
Thanks for the info, I imagine they should connect somewhere. Any ideas?
BTW, I am not sure about the positive, when I tested them with the multimeter, it read 36. I will test again this weekend and mark them all accordingly.
The reason I stated the bottom 2 were ground was because of the wires that were crimped by a screw. The metal tab the wires were installed in has a hole where a bolt was used to bolt to the metal chassis frame right above it. The OTHER wire has a crimp on ring tail and was also probably connected by the same bolt since there is no extra slack. Very possible that the wires were never mounted to the frame from original build. Doug
