Old-Biscuit
May 28, 2015Explorer III
Trackrig wrote:
The freezer is what cools the refrigerator.
Bill
Freezer and food section are 2 separate components of fridge.
Freezer temp has nothing to do with food section temp.
Freezer has it's own evaporator section and food section has it's own.
Fridge thermostat controls temp based on food section temp sensing via thermistor
OP.....
If food section is very cold (close to freezing items) then turn temp set point down.
Most RV fridges do not have defrost cycles
If freezer has ice build up........check door seals for leakage.
Otherwise.if temps good...then defrost as needed.
Having RV issues? Connect with others who have been in your shoes.24,386 PostsLatest Activity: May 13, 2026
