Executive45
May 28, 2015Explorer III
When I had my Norcold, in high humidity I had to defrost every couple weeks. I removed everything from the freezer, then used a turkey baster to spray the ice with hot water. Used rags to remove the water, then repeated until I was able to get all the ice out. Once all the ice was removed, I dried the freezer and put everything back in.
The fridge companies, Dometic and Norcold specifically say not to use sharp objects and/or heat guns/hair dryers as they could possibly damage the plastic used inside the box....good luck/...Dennis
Having RV issues? Connect with others who have been in your shoes.24,386 PostsLatest Activity: May 13, 2026
