dougrainer
May 03, 2016Nomad
A BAD Temp Thermister will test(ohm) out correctly. Replace the Temp thermistor. I have NEVER found a Control board to cause cooling problems. The board reacts to the Temp Thermister. Do you have the AUTO temp system? From you tests it would appear so. Answer the question another asked----Is this refer in a slide room? If it got as cold as you stated bypassing the control board-----DO NOT trust that RV service center again. Doug
Having RV issues? Connect with others who have been in your shoes.24,405 PostsLatest Activity: Aug 12, 2026
