Ojibwa53's avatar
Ojibwa53
Fridge stopped geting cold on electric
Dometic #2652 stopped getting cold on electric power source, can hear the fan running all the time . Turn switch to gas and it fridge went back to running normal . I unpluged, check fuses, checked thermister on fin. turn back to electric and it ran normal for 4 days then stopped getting cold again, no check light came on, fan just kept running all the time again. So I switch back to gas and it is running normal again. Any ideas on whats going on, snowbirding in FL. till April.
  • assuming you have 110 at the plug, look for loose connections the ....
    Old-Biscuit wrote:
    Check light will only come on if gas fails....nothing to do with electric failing.
    5A fuse on lower board is for electric heating element.
    Electric heating element could be bad (unplugged and tested at leads....S/B 44 ohms)
    Check 110V AC power at outlet fridge is plugged into
    Check for AC power at lower circuit board
    J5----AC line voltage (Black)
    J6----AC neutral line (White)
    J7----AC neutral out to AC heater
    J8----AC line out to AC heater Switched side
    Could be bad AC circuit, bad connection on plug(s) outlet and on board, could be bad lower board
    Testing for AC power and where it isn't will ID probem vs just throwing parts at it
  • Thanks for all the info. will try the drop light tomorrow see if the plug is bad. also will borrow a Ohm meter to test circuits, checked lower fuses already, all good. Check light never came on ether AC or gas (which doesn't light anyway). I have a surge protector hook up at the shore pole,( think maybe its not getting enough power to the fridge? ) I've used 30 protector since rig was new in 2011.
  • Wow! we must be getting better....a full page of helpful hints and not one suggests pulling it out for a residential......:W.....Dennis
  • wa8yxm's avatar
    wa8yxm
    Explorer III
    WOrks fine on Gas, not on electric.
    4 suspects in physical order
    1: No electric (breaker, wiring fault, check using test lamp (Drop lamp or trouble lamp) at outlet in outside compartment
    2: No electric (Plug fell out of socket, see 1)
    3: Bad control board. Not closign 120 volt relay or bad relay
    4: Bad heat element or wires to heat element bad (Suspect #1 by the way).
    To test.
    Start by unplugging the 120 volt plug and plugging in a test lamp.. LIGHT good, dark bad
    Now using test leads and some care and caution DO NOT TOUCH EXPOSED METAL
    attach clip leads to the heat element leads Either end is ok, the other end of the clip leads goes to teh test lamp.. INSULATE THE PLUG (I like to shove it in a plastic container with lid) and plug the unit back in, Switch to AC and see if the light, lights (NOTE Fridge must be warm enough to turn on) If light lights, ti's the heat element, if fridge hits 45 degrees with T-Stat set to coldest and light is NOT on, it is the control board
    Dinosaur boards are best.
  • Check light will only come on if gas fails....nothing to do with electric failing.
  • Check is ONLY if it does not light on LP. There is no indication of a 120 control problem. Other than no cool. If your line voltage drops below about 104 volts it will go to LP but continue cooling correctly. If the line voltage is between 104 and 110, the heat element will not be as hot as it should be. Low line voltage will cause a Heat Element to not heat to its full potential. Heat Elements either work or do not. Have you checked your 120 voltage when this happens? Doug
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 03, 2026
