We have a '96 Georgie Boy on a Chevy P30 chassis ('96) and a chevy 454. Does anybody know where the fuel pumpr relay switch is and also the fuel pump ? Thanks in advance. Nan
Fuel pump is in the tank Fuel pump relay is mounted inside the doghouse opposite side of the housing from gas pedal. Relay only runs for a few seconds after turning on the ignition switch. What is your problem or symptoms? Your engine should be a 7.4!
