We have a '96 Georgie Boy on a Chevy P30 chassis ('96) and a chevy 454. Does anybody know where the fuel pumpr relay switch is and also the fuel pump ? Thanks in advance. Nan
Pressure could be leaking back to the tank. You could try turning the igntion switch on for a few seconds two or three times. This will give the pump more time to get the fuel to the TBI. Have you changed your filter on the frame rail recently? A clogged or partially clogged filter will restrict the fuel flow.
