enblethen
Nov 03, 2017Nomad
Look for a circuit breaker in the furnace, normally mounted to fan housing. it should have a small red or white reset button.
Another problem could be thermostat. remove the cover, if two wire unit connect the two wires together. Fan should start immediately and produce heat in 10-20 seconds. separate the wires and the furnace should go into cool down and shut off.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 27, 2026
