MrWizard
Nov 03, 2017Moderator
Is the fridge on propane?
The water heater?
Do the stove burners work?
LP regulator might be froze up,
What was the overnight temp?
The heater fan should come on an do a Purge blow before the burner lights
If the fan does not come on, it's either a power problem or a control board problem, could be a bad connection to ground..rtc
The water heater?
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 27, 2026
