charlesdennis01
Nov 03, 2017Explorer
MrWizard wrote:
Is the fridge on propane?
The water heater?
Do the stove burners work?
LP regulator might be froze up,
What was the overnight temp?
The heater fan should come on an do a Purge blow before the burner lights
If the fan does not come on, it's either a power problem or a control board problem, could be a bad connection to ground..rtc
Thank you for the respond and have checked the propane as well, everything that works with propane works including the fridge, I have bypass the thermostat and still getting the same buzz noise when turning the heater on.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 27, 2026
