myredracer
Jul 11, 2013Explorer II
Furnace will not run after reverse polarity
Several months ago a friend de-winterized their trailer but he re-installed the battery backwards in reverse polarity. We were camping together and kept smelling a rotten egg smell. Thought it was someone else's sewer. Then we heard a repetitive clicking and then we discovered the battery was in wrong and the noise was the circuit breaker on tongue tripping and resetting.
Everything survived except for the furnace, Suburban SF-30F. Thinking it was the control board, we replaced that today (they got along with a ceramic heater since). But the furnace will not run at all. No fan, no noises, nothing. Measured 13.4 volts are rear of furnace, so that's okay. Tried to simulate the thermostat operating and crossed the t'stat wires together at rear of furnace. Nothing.
One funny thing is that when the thermosat is set to the heat position, the AC unit comes on. Switching it to AC doesn't bring the furnace on but seems to start the AC fan only (would have to double check this). Why would the AC work on heat position? Makes no sense. Is there a relay somewhere that's damaged?
Only other thing I can think of at the moment is maybe the blower motor is shot? Wouldn't explain the AC coming on though on heat mode. Checked the online manual and didn't help.
Any thoughts? We don't want to get defeated by this and have to pay $125/hour to troubleshoot and repair it. He won't be installing a battery backwards again either after this....
