joebedford
Oct 04, 2017Nomad III
When you have an intermittent connection, the more often you attempt to light the furnace, the more often it will work or not work. Seems pretty obvious now that I type it.
The wires that I said to wiggle are behind the exterior furnace door around the gas valve. I'm pretty sure they're all low voltage so no chance of electrocution. Wiggle the wires until the furnace comes on.
On my rig, I pulled every furnace connector off and used pliers to tighten up the females a bit. Probably just pulling off and reinstalling cleaned the connection enough to get rid of the intermittent but tightening can't hurt.
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 21, 2026
Related Content
- Feb 01, 2026Community Alumni
