- westendExplorer
j-d wrote:
EDIT - Here's a black 1-1/2" flange by Valterra on Amazon, surely there are 3" ones as well.
Thanks j-d. That's just what I needed to know. I understand that most folks can just replace the gate and seals but I need a drain plumbing makeover.
Currently, my 3" drain valve is a steel gate with lever handle. The gate won't open fully as the handle hits the trailer bottom. It was probably a previous owner that was tired of servicing the typical valves.
I have complex plans ahead with my tanks and plumbing, installation of a second tank, containment and heating pads, etc. It's a dirty job but someone has to do it. ;) - hypoxiaExplorerGood advice you are getting. You do NOT want to change the flange unless it is cracked.
- lj2654Explorerdont overtighten the screws when replacing them.....very snug yes but stop there...I know because, well I just know!
- j-dExplorer IIOP - This is what you'll get in a valve kit:
This kit is CAMCO. I pictured it because the Valterra pic didn't show the small parts as well. Those are the two common brands. At least Valterra offers some with metal handles.
Westend - Do you need more than that? I know that sometimes pool and spa plumbing uses gate valves. Flanges might be available through the pool supply. Probably white, though.
EDIT - Here's a black 1-1/2" flange by Valterra on Amazon, surely there are 3" ones as well. - lanerdExplorer IIOn line - Amazon, Camping World, etrailer..... any rv store/parts house... even marine stores/parts house.
No cutting... no glue. Take a close look and you'll see the four small bolts/nuts that holds it together.
Ron - westendExplorerDoes anyone know where to buy the gate and flanges, included? I want to do a removal of the valve and need the whole thing.
- j-dExplorer II
irollman wrote:
OK, so does "replacing", which I'm inclined to do, involve cutting off the old one, leaving enough of a "flange" to glue the new one on?
NO NO NO NO
The flanges are a one-time install. The valve is sandwiched between those flanges and sealed with a square cross section O-Ring on each side. Little bolts hold the sandwich together. New valve comes with new bolts/nuts and the O-Rings. - BarneySExplorer IIIMoved to Tech Issues forum from DIY.
- Bill_SatelliteExplorer IIThey should be bolt on connections.
- irollmanExplorerOK, so does "replacing", which I'm inclined to do, involve cutting off the old one, leaving enough of a "flange" to glue the new one on?
Having RV issues? Connect with others who have been in your shoes.24,320 PostsLatest Activity: Sep 20, 2025
