irollman's avatar
irollman
Gate Valve Replacement
I have a little bit of leakage. Who makes the BEST gate valves? The one that needs replacement at the moment is the black water one (3"?).
  • You are right, for the price of the valve I would just replace it. I only want to do that job once.:R
  • There are only a couple of mfr and they are pretty much the same.
    Many times the problem is as simple as the gasket getting out of alignment - the fix however requires you to disassemble the gate valve and many will just replace the entire gate valve as they aren't that expensive.
  • Valterra is likely what's on there an it's likely what you should replace it with. I just did my black tank valve and all the cleaning in the world would not have fixed it. However, I later found that they sell just the seals and replacing the seals alone would also have fixed the problem. If you can see the name on the side of the valve, see if you can get new seals. It's a very easy job unless you forgot to empty that black tank and tilt the RV the opposite direction! :E
  • I don't know if there is a good, better, or best valve. Mine leaked when new and it took the dealer 3 tries to fix it.
    Buy a new valve and let us know.
Having RV issues? Connect with others who have been in your shoes.24,319 PostsLatest Activity: Sep 19, 2025
