BlunderLust's avatar
BlunderLust
GEL versus AGM
I watched a video were it was suggested the max DOD of Gel Cell is 80 percent versus 50 percent of AGM and the charge time for both is around 2-3 hours. A max DOD of 80 percent would put the Gel Cell in the league of the LITHIUM batteries.
If anyone has used the GEL Cell batteries does an 80 percent max DOD seem correct? Also, does a charge time of 2-3 hours sound right?
I am thinking I might be using a HONDA or YAMAHA 2000 WATT generator to charge the batteries while boondocking.
  • Gel batteries have a very specific charge rate, cannot be allowed to heat up, or it forms gaps in the gel
    Besides when you go for batteries any thing in consumer group size to fit the RV is most likely agm
    Gel is not common in larger sizes
    Gel is old tech from the start of the space program in the 50's
    Some are mfg for specific applications
    But most have been replaced with agm
  • Hi,
    Depth of cycle is only one part of the equation.
    Recharge and discharge rates have to be much lower with gel cells. Exceeding the safe rates will result in permanent loss of capacity. If you never use an inverter gel would work well, provided that the converter used for recharging has a setting for gel.
  • I've not seen a 12v Deep cycle gel cell other than an AGM, but there's several blank spaces in the question. The DOD delta here is 30%, so if you are proposing to charge either of them in 2.5 hrs for example, the charge time is obviously going to be considerably different. You also didn't mention the capacity of either battery you were looking at. Either way need to return what you pulled out of either battery. Personally I would always go with what can be drawn down the farthest without nuking the battery.
Having RV issues? Connect with others who have been in your shoes.24,350 PostsLatest Activity: Nov 11, 2025
