MrWizard
May 27, 2015Moderator
yeb sorry about that
Sucks Cool Air to mix with the exhaust
Gen Turi aka generator Venturi
hot exhaust enters the pipe
the pipe is specifically designed to cause a swirling of the air as it rises, this sucks in the cool air and mixes it with the exhaust
djousma wrote:MrWizard wrote:
Do not use the bolts holding the existing exhaust screen
Two things
a genturi I'd not a normal sealed extension it ducks on cool frag sit to mix with the exhaust
Also the generator exhaust pipe will break if there is anything attached on the end and vibrating
huh?
