Truckguy2000's avatar
Truckguy2000
Generac generator won't shut off with switch
Yes I have a lance truck camper, with a generac generator. The issue I'm having is sometimes, most times it will not shut off with the switch on the panel or the one on the actually generator. I actually have to turn the propane bottles off to get it to die. I did change the switch on the board inside the camper with no luck fixing the issue. Hopefully some one can point me I the correct direction, as to what might be going on. I'm a bit puzzled and google so far has not been much help. Thanks in advance for any light y'all can shed on this issue.
  • It's a impact-34lp. I've been just turning the propane bottles of and killing it that way, when the switch isn't. I'm pretty mechanical incline, but I'm not very up to par on generators. I do think this is a wiring issue, or sum switch or mechanism not working properly. I'm just not real sure were to start. Thanks for all the help so far and hopefully with that model number, you maybe can pin point the issue a bit more. Hope to hear from y'all soon. Thanks again
  • Hope you can come up with a schematic.
    Not a permanent solution, by any means, but just to get it to shut down you may try closing the choke. I have had similar problems with small engines and used this until I could get repairs.
  • Do you know the model number? I looked at a couple Generac schematics. There are probably similarities across the model line up. They run a negative to the main switch and in the start position it sends that negative to terminal 17 on the board. To stop they use the same negative and send it to terminal 18 on the board. SO, we know that the start function works all the time because the same feed is common to start and stop. So we know the negative is always present.
    The same type of piggy back circuit is also on the engine or generator itself. It uses a negative to both start and stop the engine by sending the negative to the appropriate card terminal. It's extremly unlikely that both stop functions have failed in oth stop circuits. So what that tells us is that the problem would seem to be between the card and and the engine ignition module or coil. At worse it could be the card itself. That could be tested for by finding the negative out of the card and seeing if negative is present when either the main or the remote are in the stop position.
    My guess would be to check for a loose connection between the card and the ignition module.
    This circuit could have a harness coupler in it. Sometimes the flat blade or barrel type connectors can become loose and cause an intermittent problem such as you describe.
    I do not know your abilities or who you may have work on this issue but DO not use any 12 positive jumpers in the ignition circuit. The ignition system works by applying a ground to the ignition module. Power will fry it. Again we need your model number but this is my best guess with just using some Generac model similarities.
Having RV issues? Connect with others who have been in your shoes.24,344 PostsLatest Activity: Dec 22, 2025
