- George3037ExplorerI have three generators. two purchased new for camping and one larger unit for house backup. Broke-in the house gen years ago. The new ones have a break-in procedure in the owners manual (manual not in front of me to quote from) but basically to run the gen under a load of up to 75% for 5-6 hours then change the oil. Broke them in last year when purchased.
I used a couple small electric heaters for the load and varied the load. - 2oldmanExplorer II
mrad wrote:
Then I'd just let it idle for a minute or so before loading it up.
Owners manual just says to change oil after 10 hours. - mradExplorer II
2oldman wrote:
Owner's manual.
Owners manual just says to change oil after 10 hours. I know with some other small engines I have had, the dealer recommended a couple hours at low rpm and then ramp it up.
On other topic, I have noticed that just about all non-honda inverter generators have a 79 cc motor. Is the same manufacturer making all of the engines for these?
I know yamaha used to make engines for a couple of brands that were their 79.something cc engine. - BarabooBobExplorer IIIMy Champion 2000i manual says to run the gen for 5 hours at less than 50% load and change the amount of load to help the gen not get overly hot. After the first 5 hours., change the oil.
- 2oldmanExplorer IIOwner's manual.
- BFL13Explorer IIMy B&S portable 2200w just says to change the first oil after 10 hours. (That is to get rid of initial wear metal shavings in the oil, then you are good till regular oil change time.)
Having RV issues? Connect with others who have been in your shoes.24,343 PostsLatest Activity: Dec 14, 2025
