wa8yxm
Jan 08, 2018Explorer III
The most common "Generator hour meter" is. in fact, a spring wound clock.. Like the dash clocks of the 1950's and 1960's it has a magnetic solenoid that "Winds" the clock (the spring is only good for a couple of minutes)_ when the spring is wound the switch that operates the magnet is opened. and as the clock winds down the switch closes, there is a soft "Click" lasting less than one clock tick and the spring is re-wound.. This is why the clock continus to run or a bit after you shut down the Genny.
Suspects if it does not work
Broken wire, no power to the wire
Dirty switch contacts
Bad magnet wireing
Clockwork issues (See a horologist for this one.. Folks Horus is the God of Time so a Horologist is one who studies time or time pieces, or fixes time pieces.)
Bad magnet wireing
Related Content
- Feb 01, 2026Community Alumni
