POSSUMJOE's avatar
POSSUMJOE
Generator not charging coach battery
2002 Newmar M/A DP 400 isl leece neville alternator or generator won't charge batteries. Alternator not putting out 12 volts. Should my onan generator charge my batteries?
  • Rjensen726 wrote:
    I have a Cuumins QG4000 gas unit and generator is not charging the Gen battery on my unit either. Isn't there an alternator in the genset to charge the battery? My application only uses 120v appliances and lighting. There is no external charger connected to the Gen battery.
    NO, Most Gensets do not have a charge system, especially RV designed Gensets. Powertech gensets, you can order an optional charger module that is just to keep the battery up from the 12 volts used by the genset. You need to just get a battery maintainer type 120 charge module to keep your battery up. Doug
  • I have a Cuumins QG4000 gas unit and generator is not charging the Gen battery on my unit either. Isn't there an alternator in the genset to charge the battery? My application only uses 120v appliances and lighting. There is no external charger connected to the Gen battery.
  • dougrainer wrote:
    On a 2002 Newmar MADP, your APU (genset) does NOT charge anything. It has no charger. What it does on your model is this--- Once the Genset powers the motorhome, you have an Inverter/Charger and THAT charges the coach batteries. Your system also has an Intellitec Bi charger system. Once the Coach voltage comes up and over 13.1 volts, the charge relay closes and this supplies charging to the chassis batteries. The Chassis engine Alternator supplies charge voltage DIRECT to the chassis batteries. Not thru any other appliance. So, if the chassis Alternator is not charging, you need to find out why. The chassis Alternator if functioning WILL charge the coach batteries thru that Intellitec bi charger relay system. Doug
    MOST 2002 MADP had the Inverter/Charger, but some had 2- 40 amp Power converters. Doug
  • On a 2002 Newmar MADP, your APU (genset) does NOT charge anything. It has no charger. What it does on your model is this--- Once the Genset powers the motorhome, you have an Inverter/Charger and THAT charges the coach batteries. Your system also has an Intellitec Bi charger system. Once the Coach voltage comes up and over 13.1 volts, the charge relay closes and this supplies charging to the chassis batteries. The Chassis engine Alternator supplies charge voltage DIRECT to the chassis batteries. Not thru any other appliance. So, if the chassis Alternator is not charging, you need to find out why. The chassis Alternator if functioning WILL charge the coach batteries thru that Intellitec bi charger relay system. Doug
  • Hi,
    Sometimes. If it doesn't a trik-l-start unit can be added.
    64thunderbolt wrote:
    will the gen charge the chassis batt? Just curious.
  • Your onan should provide 110 Volts AC to the "Convertor" and the convertor should charge your battery. Make sure the convertor is plugged in to an 110 outlet and that all the 110 breakers are turned on and not tripped.
