My rig is a 2011 Four Winds 28A I have a 4KW Onan generator built in to it. When I remove the generator dip stick after sitting for days it shows no oil. If I screw the dip stick back in and rem...
If dipstick is showing half full then it's half full. pull the dipstick and shine a flashlight in the hole or stick your finger in the hole and see if there is oil if you don't believe the dip stick. Oil should be an inch or so below the top of the dipstick hole.
Having RV issues? Connect with others who have been in your shoes.24,211 PostsLatest Activity: Mar 09, 2025
