My rig is a 2011 Four Winds 28A I have a 4KW Onan generator built in to it. When I remove the generator dip stick after sitting for days it shows no oil. If I screw the dip stick back in and rem...
You must have one of those dipstick with long tube and well sealed cap on top. Those create vacuum, or pressure in the tube depends on temperature, so the readout first time doesn't count. Pull the dipstick, wipe it off, reinsert and then check.
Having RV issues? Connect with others who have been in your shoes.24,211 PostsLatest Activity: Mar 09, 2025
