SKSCCI's avatar
SKSCCI
Generators - Gas, Diesel or Propane, Best makes models?
Good Morning All!
At a recent weekend campout, the entire campground lost power for some reason.
Not a hardship as it was mid Sunday morning and we were preparing to leave anyway.
However, if it were any other time it could be a hardship.
My AC Voltage needs are minimal as the propane provides for heat and cooking.
However, Air Conditioning in Florida is a must, especially with the dogs.
So, as a minimum I probably need a 2KW generator.
I have a diesel truck so there is a ready supply if I want to siphon, or have a can for dual usage for the vehicle or generator.
Recently at TSC I saw a propane fueled generator and that seemed like a great idea since I already have 2 20 lb tanks and could always replace them with 2 30 lb tanks.
I have also seen conversion kits that would allow me to use gasoline, diesel or propane for a generator. Would something like this be better?
Another factor is being able to move it around conveniently.
The only available storage would be the back of the bed of the pickup
truck tow vehicle, so it has to be light enough for me to lift it in and out of the truck.
So . . . basic questions . . . fuel type pros/cons, make/model pros/cons and KW capacity considerations.
Thanks.
Regards,
Steve.
  • Bobbo wrote:
    Honda or Yamaha are the top recommendations.
    Not true. Champions are.
  • Bobbo's avatar
    Bobbo
    Explorer III
    Honda or Yamaha are the top recommendations. Many like to get 2 of the Honda 2kw units and parallel them for heavy usage.
  • We have a multifuel Yamaha 2400is that can run on gasoline but has only ever run on propane.
    A 2000 gen likely will not start and run your AC. Depends on watts required.
    The mutlifuel is more expensive.
    You will be told that it is more expensive to run on propane, probably true, but I have mine for the convienience of not having to carry gasoline.
    Propane won't gum things up when the generator is sitting around unused.
Having RV issues? Connect with others who have been in your shoes.24,349 PostsLatest Activity: Jan 16, 2026
