DarkSkySeeker's avatar
Jul 01, 2021
GFI Breaker
So I warned the GF not to plug in 5 appliances to the outlets in the kitchen. She did anyway and the plugs stopped working, including the kitchen, living room, and outside plugs. All of the dead plugs are labelled "Ground Fault Protected" but none have resets or test buttons.
Turns out the bedroom and TV outlets are on their own circuit. The bathroom has a GFCI plug that tests, resets, and works independently of this problem.
A lot of the rest of this post is guesswork.
So I opened up my breaker panel and there is a 15amp circuit labelled "GFI" (no "C"). I bought another breaker ($25) and replaced it and the "failed" circuits continued to not work.
About an hour later, mysteriously, they were on.
Here's the real guesswork...
The contacts on the old breaker looked bent. While on there was continuity but I could not tell if power was getting to it through the bent contacts. I can not explain the hour long delay before power was restored. Some sort of reset process/lag?
Your thoughts?
Having RV issues? Connect with others who have been in your shoes.24,277 PostsLatest Activity: Jul 01, 2025
