klutchdust's avatar
klutchdust
Explorer II
Oct 20, 2017
GFI replacement on inverter (update) need some more advice
Can it be done. I see a few pop rivets holding the inverter cover on . The inverter is mounted under the sink and difficult to remove ,being on the road with limited tools doesn't help. It's a Levitron part. This inverter is for nothing more than the outlet in the entertainment center to run the TV when not plugged into ground power or generator?
So i found Mike's mobile RV service at the race track ,he is from Bakersfield . He looked at the inverter and said that he has never seen one with a GFI switch on it, maybe a GFI with a receptacle to plug something into it, but not what I have.
I asked him to come and look at my reefer because when i opened the door to start dinner the door fell off. The plastic part on the bottom that sits on a small pin to swivel on, call it a hinge pin if you like , broke. The door needs to be replaced . He thought he had a used one but he didn't . Ordered one on the net and it should be here before I leave for Vegas on Wednesday. Shameless plugs allowed? Mike is a real decent and fair man, if you need something and are in that area I wouldn't hesitate to use him.
