I have a EPDM rubber roof. I need to attach a galv. steel plate to the roof to the roof for a mag antenna. What is the best glue for that? I will be using self leveling Dicor around the edges, after...
Kiwi, I've added some thoughts after you've posted. Hmk is right, large rigid items should better be screwed through the EPDM to the plywood - not glued.
