egarant's avatar
egarant
Nomad
Aug 03, 2015
Gluing Rubber
The top rubber strip on my slide, lays over the top of both side rubber strips on my slide out. I noticed that one side is glued and the other is no longer.
It is a simple fix, but what would be the best product to use....is the answer too obvious, Rubber Cement? Or is there something else someone has tried that is better?
Thanks!
  • Pro-Seal CS3204
    This is the messiest stuff on earth, but if you are serious, it will stick forever and it stays flexible.
  • I reattached part of our slide rubber seal. It had some double sided tape that just failed. The 3m super strength auto molding tape as mentioned so far is working. Its pretty awesome stuff.
  • 3M weatherstrip adhesive , at most automotive stores .
  • GOOP makes all sorts of adhesives for automotives uses, including gluing weatherstripping back onto steel
  • Look at PlioBond, it's a water proof adhesive that stays flexible in all weather.
  • This product is what I've used on my slide seals to secure them to the wall. Not sure if that's what you're after.
