I have a EPDM rubber roof. I need to attach a galv. steel plate to the roof to the roof for a mag antenna. What is the best glue for that? I will be using self leveling Dicor around the edges, after...
What size plate? Big enough for the ground plane or just the magnetic base? What size antenna?
A ground plate base for a 440 MHZ 1/4 wave, with aluminum tape radials probably has different needs for attaching it than a full ground plane plate for lower frequency.
Jim
