I have a EPDM rubber roof. I need to attach a galv. steel plate to the roof to the roof for a mag antenna. What is the best glue for that? I will be using self leveling Dicor around the edges, after...
Antenna is 12" Wilson. 3/16 by 8" round galvanized steel. After considering the weight I went with a single 1 inch screw thru the middle with Dicor under and sealing the edges.
Thanks to all for the advice.
