jaycocreek
Sep 29, 2021Explorer II
I guess it is the first two parameters that I don't understand at 15 and 16 volts compared to: Battleborn suggest the following settings,
Over Voltage Disconnect 14.7 V
Charging Limit Voltage 14.6 V
Over Voltage Reconnect 14.6 V
Equalize Charging Voltage shut off or 14.4 V
Boost Charging Voltage 14.6 V
Float Charging Voltage 13.6 V
Boost Reconnect 13.3 V
Low Voltage Reconnect 10
Under Voltage Warning Reconnect Voltage 11.5
Under Voltage Warning 11.5
Low Voltage Disconnect 11.0
Discharging Limit Voltage 10.5
Equalize Duration 0 or set as low as possible
Boost Duration 180 minutes
I have been running my AGM(sealed) off of the solar through the controller and will be using Lifepo4 here shortly and don't want to fry it not knowing much about co0ntroller settings..I have the USER numbers but just can't get them to take yet even though "read" and "set" show successful it changes back to default....LOL
Having RV issues? Connect with others who have been in your shoes.24,372 PostsLatest Activity: Mar 30, 2026
