djgodden's avatar
djgodden
GoPower! SW-3000-12 Inverter Shutdown?
Ok, I know there has to be a simple answer to this but I'm hoping the collective brain here can give me one.
I purchased and installed the subject inverter. Everything in the fifth wheel works brilliantly, except... when I turn on the microwave (even with nothing else in the RV powered up) the inverter shuts down. The MW is a 1500W combined convection/MW type and I thought a 3000W inverter would power the MW portion for more than a few seconds since it has a 6000W surge capability. Is the start up demand exceeding the inverter capability?
Edit: Just in case it matters. The way I tie the inverter into the power is through a 50 amp cable hard wired into the inverter and then plugged in just as shore power would be. Turned on and off via the remote.
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 04, 2026
