MNtundraRet's avatar
MNtundraRet
Navigator
Jul 29, 2016
GPS suction cup adherence to windshield
Has anyone found a way to attach the suction cup holder to their windshield?
Normal suction attachment fails with temperature change. I have tried taping the suction cup to the windshield with plastic tape, or Gorilla tape with tape eventually loosing adhesion due to weight of unit, vibration, or temperature changes.
I am thinking of super-gluing the cup to the windshield as a last resort.
:M
  • Some suction cups are much better than others. But a clean suction cup and a clean glass is your best hope.
    If a GPS, I much prefer the beanbag type dash mount to a suction cup mount. Down low out of line of vision, and easy to move to floor out of sight when vehicle is parked.
  • Cleaning good with alcohol wipes helps somewhat, then clean it each time you remove and replace. The changing temps will harden the seal, and it does need to be removed and reset often.
    Also, be sure and clean the little circle off the glass whenever you remove and store the GPS. The little circle is a sure indication to everyone that you have a valuable GPS in the vehicle. You could end up with a lot of broken glass even with the GPS hidden.
  • Ditch the suction cup. They age too fast sitting on the glass and will not hold for very long, even if conditions are perfect. I have one spot under the windshield glass where I have permanently adhered a pad of 3M "Hook and Loop". This is similar to Velcro in concept but is much stronger. The hooks and loops have a very positive hold. I use this pad for GPS antenna or anything else I want up there. I have door-mounted audio tweeters, they are also adhered with this material and they stay in place through many door slams.
  • Please dont super glue anything to your windshield. There are PAGES and PAGES of various GPS type car mounts on Ebay. Find an alternative to the suction cup if its not working for you.
Having RV issues? Connect with others who have been in your shoes.24,322 PostsLatest Activity: Oct 07, 2025
