Wikel's avatar
Wikel
Gut check lithium 4S6P battery connections
Still working to figure out this whole solar battery thing. This is focused on:
1. The series interconnections between 3.2v lithium battery cells to create a larger 12v nominal pack.
2. The parallel interconnections between 12v nominal packs to create a larger AH battery array.
3. The link between the positive and negative connections and the upstream charging / discharging components using the battery array.
1. Would this be a correct setup and if not, what needs to change?
2. Is there a more effective way to arrange the battery configuration. If so, how and why?
Thanks for any feedback!
Having RV issues? Connect with others who have been in your shoes.24,245 PostsLatest Activity: May 11, 2025
