dave17352's avatar
dave17352
Explorer II
Aug 06, 2014
hard wired my converter in but not sure of polarity
I hard wired my new converter into my Magnetek 7345. It fit right into the lower opening. Everything is running great. But my question is this. I believe when I cut the plug off and wired it into the box I got the polarity right but not 100 percent sure. The three wire cord had a green in the middle and both just black insulated on either side. My question is will this cause a problem if it is backwards. If so what type of problem. Like I said everything is running properly it appears but what should I know that I don't? I realized at the time the big blade is neutral, but I just wasn't sure when I hooked it up.
Thanks in advance for any advice.
Dave
  • RoyB's avatar
    RoyB
    Explorer II
    Here is a schematic of a similar WFCO 8700 series wiring using BLACK-GREEN-WHITE colors - might help
    The BLACK goes to the Circuit breaker connection.
    The GREEN wire eventually goes to frame ground.
    The WHITE WIRE goes to floating NEUTRAL (NOT GROUNDED)
    Roy Ken
  • Okay I am going to be looking for ribs or markings this morning. I did read up a little bit on this, and correct me if I am wrong. In this particular application isn't it really a non consequence if the polarity is switched or did I miss understand something?
  • haddy1 wrote:
    smkettner wrote:
    Is it a flat zip cord? Usually it will have some ribbing on the outside that I believe is the neutral. Compare to the plug wire that was cut off.
    X2
    On some cords, instead of a rib on one wire, it will have the wire size and specifications running down the neutral side.
    X2
  • Is it a flat zip cord? Usually it will have some ribbing on the outside that I believe is the neutral. Compare to the plug wire that was cut off.
  • newman fulltimer wrote:
    every one i have wired had a black green and white wire and i have wired tones of them
    I have wired several myself. This cord did not have this. Like I said it had a green insulated wire in the middle the two outside wires are sheathed in black insulation. I believe I did get it right just not sure and curious as to any problem this could cause. Of course the green wire is grounded.
Having RV issues? Connect with others who have been in your shoes.24,368 PostsLatest Activity: Mar 11, 2026
