catkins's avatar
catkins
Explorer II
Jan 02, 2016
HELP - solar controller (monitor???) failed
I have Blue Sky IPN - ProRemote installed inside the RV for ease of checking status. Literally touched it tjis AM, saw a spark fly the around entire unit and now have a zapped dead panel.
So sitting on the desert worried about overcharging,. I have two Blue Sky Solar Booster 3024i controllers installed in the bay.I BELIEVE these actually controll the battery charging and the inside unit is simply a monitor?? Can anyone verify if my thinking is correct. I know just enough to be a bit dangerous...............
I am concerned that I not overcharge the batteries. Will monitor and turn off solar input if it gets too high but wanted the check the wisdom out there.
Thanks in advance
Having RV issues? Connect with others who have been in your shoes.24,343 PostsLatest Activity: Dec 11, 2025
