MrWizard
Jan 04, 2014Moderator
How long have you been parked at home and plugged in?
If this is a new situation, . If so my guess with the info available is you plugged into a 240v DRYER OUTLET
These are three wire , two hots and a ground , No Neutral and will burn out all the electrical items in your RV
Voltage has to be measured at the OUTLET you are plugged into
Having RV issues? Connect with others who have been in your shoes.24,394 PostsLatest Activity: Jun 18, 2026
