RV_Tech_101
Jan 04, 2014Explorer
Your best suggestion is get a hold of a qualified RV tech. Not an electrician. Most electricians are clueless beyond wireing a light switch and can cause more damage than you already have. I agree it sounds like a 50 amp coach with an open nuetral. Real simple fix. Check all wire connections in the distribution panel and transfer switch (if applicable). Next check power source. If you know nothing if 50 amp or 30 amp plugs then this is where you need the tech. If it is an open nuetral be prepared to replace your converter and maybe some other more expensive items because your coach just got hit with 220.... oops!
Hope this helps
David
Harrison RV
Hope this helps
David
Harrison RV
Having RV issues? Connect with others who have been in your shoes.24,394 PostsLatest Activity: Jun 16, 2026
