CA_Traveler
Jan 05, 2014Explorer III
LScamper wrote:Yes a good test but it puts expensive equipment at risk.
MEXICOWANDERER has the best 100% sure way to find an open or high resistance nuetral.
Do not plug in anything to the 50A plug until the problem is found. You will just destroy more equipment.
If the 50A neutral problem is before the adapter then you could easily get very high voltage in the rig. ie It certainly could be the wiring on the 50A pedestal plug or the plug itself or even upstream from the pedestal.
If you take my suggestion to disconnect or remove all equipment and then only use lower cost loads then this is a good approach.
Having RV issues? Connect with others who have been in your shoes.24,394 PostsLatest Activity: Jun 16, 2026
