naturist
Nov 28, 2018Nomad II
I’m just in the process of going solar on the RV, so have no answer to grounding question. In principle, grounding everything is a good idea. I put in an extra ground rod next to where the generator goes for emergency use at the sticks ‘n’ bricks, but never bothered grounding the generator used when camping. A good ground is often easy at a campground where a clamp on the water hydrant is an easy fix. But that’s not usually when you need either solar or generator.
Having RV issues? Connect with others who have been in your shoes.24,390 PostsLatest Activity: Jun 05, 2026
