tommymsw
Jul 25, 2017Explorer
Help replacing an OLD isolator
So I am going to assume my isolator is broken (judging by how old it is) and NOT that it was wired wrong. Although it does seem to be wired differently than the instructions I see for new ones.
For example... the alternator goes to the isolator, but the isolator does NOT go to the engine battery. It is as if the alternator itself splits the charge to the engine battery and THEN also to the isolator.
Picture of My isolator
Like A,E,F are all linked together. E comes FROM my alternator and then A just loops up to the isolator (to give it power). C must be wired to my ignition to turn it on and off and I assume the BLACK wire D goes to charge my house battery (It vanishes into the firewall). Although there would then me NO "Negative" running from the isolator to the house battery.
NO LINE goes from the isolator to my engine battery, that battery is connected directly to the alternator.
line F is a mystery... (It is red) and it travels to some kind of thing pictured HERE that seems to be attached to my air conditioning (That is not working AND not even connected anymore)... Not sure if that is relevant.
So TWO questions...
1. How many AMPS do I need the new isolater to be? I saw one on Amazon that was 80 amp and I imagine the one I have is that small at least.
2. Any advice on how to connect the new one? I will just kind of copy the way it is hooked up now (even though it is slightly different than the directions say)
So TWO questions...
