1. If you want Warranty help, you need to take a LOT of good Pics all around the ripped roof. I would also take the RV back to your dealer BEFORE you fix it, not to drop it off, but to show them the results and your pics. Have them document that you came in. DO NOT let them blow you off if they state they are too busy. ANY good dealer will let you drop by just to document what happened. Failure to do that and you then get it fixed by yourself, they will probably deny warranty coverage.
2. I KNOW you think the rubber just came loose and peeled back. I have seen scores of your type problem over the years. Yes, some times it is inadequate glue by the OEM, but you would be amazed to learn that once I get on top and look at the front cap and left over rubber, I find where the Customer hit a tree limb or some such object and either pulled the rubber slightly loose from under the front Cap edge and the resulting wind at 60 mph then bubbled up and pulled it loose more. I also can then point to the areas on the rubber and the cap and even the Roof AC covers and vent covers and the rear untouched area of the existing roof showing the telltale scrape marks from the tree limbs that scraped the roof. Even the scrape marks on the Patio awning. So, if you have these type marks on your roof, rethink trying to warranty and inform your insurance company. Doug
PS, If the dealer refuses to see you, Call Heartland, document who you talk too and state you want their E mail address to send the Pics you took. That way they have a record for later warranty help.
