enblethen
Apr 12, 2022Nomad
Ground needs to go to the rig's frame.
Definitely not to the 120 volt neutral buss bar.
As in red circles, it is clear to run to rig's frame. You should run two ground wires with separate connections to frame.
Normally ground wire is oversized such as #6. Make sure frame is clean. Solid wire is preferred. No crimp connections.
Having RV issues? Connect with others who have been in your shoes.24,390 PostsLatest Activity: Jun 03, 2026
