JimK-NY
Apr 13, 2022Explorer II
I don't have a favorite calculator. Anyway, if you have a 45amp system, I would wire for that maximum amount. So that would be 5' away for a total pos-neg wire run of 10 ft. 8 gauge is not excessive. How much power you draw is only one consideration. You need to wire the system for the max charging at 45 amps. If your distance estimate is off a couple of feet, that would put you closer to 6 gauge wiring.
Having RV issues? Connect with others who have been in your shoes.24,390 PostsLatest Activity: Jun 03, 2026
