Whiskey_River's avatar
Nov 17, 2016
Honda 2000 Aux Tank
Anyone out there in forum land have any experience with the various adaptors or extended fuel kits as shown on e-bay that you add your 3 or 5 gallon fuel tank to the Honda 2000 generator.
Couple of questions: Does the kit come with a suction hose that goes down into your gas can. Pictures just show the hose from the can to the generator. And does the generator pull from the auxiliary can and keeps the on board generator tank full, meaning you just need to fill the auxiliary tank as it runs, unless you run the whole system empty. I tried to do the control C, control V to show a couple of the kits, but must need to do something else to get it to bring it over to RV net. Thanks...
  • I had one couple years back for the two generators setup, and yes the generators pull from the extra tank, I don't specifically remember if the added tank had a hose to pull from the bottom. The kit I purchased had the two caps, hoses, and the extra aux tank.
    Once hooked up, if running for a long time, you will just need to top off the extra tank. The system itself keeps the generators full (unless you run it completely dry).
    MArkiemark
Having RV issues? Connect with others who have been in your shoes.24,348 PostsLatest Activity: Jan 12, 2026
