like2rok's avatar
like2rok
Honda 2000 generator Fast Idle mode for Eco-ON extra Power
My Honda 2000 generator started up cold then Eco Switched On will start my Whynter 11kBTU portable AC after the AC's 3 minuted compressor start delay. When the AC cycles off, then tries to cycle back on the generator lugs too low and power is interrupted, the RPM's scream high then go back low after a minute. After 3 minutes the AC tries and fails to start again.
So I speculate that a Cold engine must have a high idle mechanism, that if engaged permanently would allow the generator to reliably start my AC consistently with Eco Mode On.
Any suggestions about the Cold Start High Idle mod?
    Ever think your generator is too small to handle the A/C load??
  • I have a 3000 but get the same sort of thing--some jobs you need to leave the eco off and have it running full before adding a big load.
    Anyway, I don't get it. Eco is to lower the revs to save fuel. Howinheck can you have high revs (fast idle) AND eco?
  • For running A/C and/or the microwave, I have to leave the eco switch off on my paralleled Honda 2000s. Otherwise, they just bog down and the A/C compressor won't kick on and the microwave browns out. But most of my boondocking is at 10,000 feet plus. Don't know what they would do at "normal" elevations. They've never been below 8,000 feet.
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 09, 2026
