mtofell1's avatar
mtofell1
Honda 2000i leaking gas around carb
This is NOT the rough idling due to old fuel. Been there, done that.
The generator runs perfectly but leaks gas around the top of the carburetor starting a minute or so after starting it and for about 5 minutes after shutting it off.
I've taken it apart and the gaskets all look okay (but I will likely replace them anyway). In doing some research I'm finding some information about the float sticking or being damaged but the info is kind of vague. Has anyone run across this and if it's the float, what exactly did you do to fix it?
