Gale_Hawkins
May 28, 2014Explorer
profdant139 wrote:
So you can use pure Seafoam -- no gas?? Won't it run too hot and damage the components? (That is probably an ignorant question, but that describes me perfectly.)
Good questions but I do not have a scientific answer.
Remember when I was running the pure Seafoam I was with NO load. It really was just an accident. I was just going to store the generator with the carb full of Seafoam and hopefully pickle the engine in the process. I pulled the manual choke to full closed when it started to die when the carb filled with pure Seafoam to suck as much as I could into the piston area as it died.
It just kept on running on pure Seafoam with full choke but the engine was at operating temp already.
Old gas tractors would run on gas but also kerosene after they got hot running on gas.
As Jim pointed out as well I recommend just to run 2 oz per gallon of gas (we once again can get 90 octane pure gas so that is all we buy for small engines). Even if the generator is running a little rough over time it will most likely will smooth out.
Seafoam can stick rings as well as unstick them so read the rest of this story.
We picked up a 2000 Polaris 325 Magnum ATV and I was running like a 4 oz per gallon mix for the heck of it. The tank and carb shut off valves failed and over a few days about a gallon of gas flowed through the carb filling the piston hole and flowing on into the crank case.
It was hydro locked so the starter never move the piston. We pulled the spark plug and got the gas out and drained the oil and only pure oil came out at first so I knew we were OK.
After the oil change I got it to running but with the carb shut off needle valve sticking open it was loading up some and after 15 minutes it lost all compression.
We tested the auto compression release and it worked correctly so we tore down the engine top end. I had to drive the rings out of the ring grove because they had 'coked' into the ring grove because the piston/head carbon build up was dissolved by the Seafoam gas mix and flowed it into the ring groves that cooked/coked after running for 15 minutes.
It that were to happen again to a dirty engine I would just put in a heavy Seafoam mix into the tank and let the gas flow out the oil drain plug until I thought it had flushed the dissolved carbon out the drain plug.
Folks back to small engines if one runs fine under full load the carb is OK. Run the 2 oz to a gallon (1:64 ratio) of gas and you will be fine. I love Seafoam because it works while I sleep. :)
Having RV issues? Connect with others who have been in your shoes.24,394 PostsLatest Activity: Jun 15, 2026
